One for the Megasquirt guru's
This is the spark map for my old 4.8 maybe of some use??Coops wrote:are there any ignition maps on MS for the 4.6 that i can look at to see if im getting my map the right way??
After that I went throttle bodies and alpha-n mapping, the spark table changed slightly too. HTH
Big Tone
www.cobratone.co.uk
www.cobratone.co.uk
nope i dont have that table mate:
and my ignition map so far.
mine is reg
- SimpleSimon
- Knows His Stuff
Reg cant fault the MS ecu mate,
10000000% more reliable than the vems i was using,
and more people are willing to help if you get stuck.
I too could of gone emerald, but didnt want to, i like a challenge and when i get a roller read out i know its my own work mapping it. so i feel more proud of the results.
depends who you talk to Reg.
hell yeah,
if you was to read the whole post you would of seen hot start was nowt to do with the ecu it was the air filter location
and the reason its 3 months long not used the car much this year after all the work we are doing in our new house so get little time to tinker in the garage
IAT sensor is back where it was near the plenum,
the filter work sorted it
- SimpleSimon
- Knows His Stuff
