have had a problem from day one of a type of miss fire and very lean surges under light throttle, have tweeked the fuel table no end to no change,
BUT then last night by sheer fluke we have now sorted this, it was a high spot in the ignition map which when under light throttle the car was on the edge of the high and low spot and was jumping back and forth on the ignition map
BUT this other one i can't seem to cure,
I'm still having this hot start problem, where you go for a drive park up for say 15-20mins come back fire the car up and it then gives an afr of 17-23 and hunts up and down like a bitch, switch engine off and start again straight away and it gives 13.7-13.9 and runs as normal??????
Im beat on this one,
Any clues????? IAT sensor????
