On your last point, the slave cylinder has a spring behind the piston and this keeps the CRB lightly on the fingers of the clutch.primer wrote:Hi Denis,
Yep, thats basically it. I think theres a little more than 1/2" gap but I'd like to re-check more precisely.
Your right in saying that Im running out of throw on the fork before the CRB comes into contact with the fingers. -My concern is that not only will I not be able to disengage the clutch, but also if the CRB dosnt sit back against the 'box (or pretty close), then the slack in front of it may allow the fork to find its way off the pivot ball, or the pushrod to come out of the slave cylinder.
If I get chance this evening I'll take some more precise measurements and post them up.
So no worries on that point.
Regards Denis
