I have a question now though, so thought it best time I stuck my head up!
When I bolt my gearbox upto the block I find a big gap between the release bearing and the clutch cover.
Its a P5B 3.5 motor (early CR version but machined for lip seals), SD1 flywheel, AP super heavy duty clutch plate & cover (brown?), SD1 bellhouinsg & g'box. The gearbox has a G16A code on it, which I believe means its from a 2000cc varient.
Its got me stumped. I've had a few problems with the build so far, but nothing I couldnt work out with a bit of reading and fiddling. AFAIK all the parts are 'correct', but nonetheless, the relase fork is almost flat against the back of the bellhouisng before it comes anywhere near the clutch cover? I wondered if I had some strange short pivot but with the release bearing sitting right back to the 'box on the input shaft, theres still the big gap!
Im pretty much pulling my hair out at this point. If anyone can shed any light on it I'd be over the moon!
