waterproof ignition system
V8 in a land rover for off road use. Is there a distributorless system or other ignition system that will work when very when wet?
Idris
Idris
Like a rubber glove with 9 fingers? I have seen them too, not sure how good they are.katanaman wrote:Think there is a landrover waterproofing kit. Sure I have seen them on Ebay.
I've heard that if you just seal up the distributor, it gets internal condensation. So some people suck a small amount of air through it (one pipe to near air filter, the other to inlet manifold) to keep it dry.
- Getting There
don't worry too much about that amp thingy , i run lpg on mine and petrol too .. i have ste it up to run best on lpg as i only really use petrol to start up or if i run low on gasidris wrote:That sounds good. As I run lpg and petrol I have an RPI amplifier that changes the timing accoring to the fuel type. Will I be able to achieve similar with the megajolt?
Idris
or
http://cgi.ebay.co.uk/WATERPROOF-KIT-V8 ... .m20.l1116
or this
http://cgi.ebay.co.uk/Land-Rover-V8-Mil ... 286.c0.m14
katanaman wrote:The second link I think is to stop radio interference or EM emissions in military applications and not waterproofing.
That second one is often sold as a waterproof kit, but it is for radio equipped vehicles so they can keep the engine running without interfering with all the radio gear on-board. Entirely pointless unless you're doing some kind of fancy restoration!
