waterproof ignition system
idris
Post by idris »
V8 in a land rover for off road use. Is there a distributorless system or other ignition system that will work when very when wet?
Idris
Use the coil packs from a P38 Range Rover or Series II Disco along with a Megajolt.
katanaman
Post by katanaman »
Think there is a landrover waterproofing kit. Sure I have seen them on Ebay.
katanaman wrote:Think there is a landrover waterproofing kit. Sure I have seen them on Ebay.
Like a rubber glove with 9 fingers? I have seen them too, not sure how good they are.
I've heard that if you just seal up the distributor, it gets internal condensation. So some people suck a small amount of air through it (one pipe to near air filter, the other to inlet manifold) to keep it dry.
bill shurvinton
Post by bill shurvinton »
As Chris says, megajolt+EDIS8 is the business. The EDIS module is completely waterproof and will give you a bit fat spark even when the engine bay is underwater.
idris
Post by idris »
That sounds good. As I run lpg and petrol I have an RPI amplifier that changes the timing accoring to the fuel type. Will I be able to achieve similar with the megajolt?
Idris
I don't know if the MJ does that - i.e. has two maps, selectable with an external input????
bodger
Post by bodger »
idris wrote:That sounds good. As I run lpg and petrol I have an RPI amplifier that changes the timing accoring to the fuel type. Will I be able to achieve similar with the megajolt?
Idris
don't worry too much about that amp thingy , i run lpg on mine and petrol too .. i have ste it up to run best on lpg as i only really use petrol to start up or if i run low on gas
or
http://cgi.ebay.co.uk/WATERPROOF-KIT-V8 ... .m20.l1116
or this
http://cgi.ebay.co.uk/Land-Rover-V8-Mil ... 286.c0.m14
katanaman
Post by katanaman »
First link is what I was on about. The second link I think is to stop radio interference or EM emissions in military applications and not waterproofing.
katanaman wrote:The second link I think is to stop radio interference or EM emissions in military applications and not waterproofing.
:whs
That second one is often sold as a waterproof kit, but it is for radio equipped vehicles so they can keep the engine running without interfering with all the radio gear on-board. Entirely pointless unless you're doing some kind of fancy restoration!
