RV8 bellhousing bolt pattern.
Has anyone got a drawing of the rear of a RV8 showing the dimension layout for the bellhousing bolts and dowels etc.
Denis
Denis
I've got a few blocks in the shed Denis.
would you like me to do a rubbing of one or tap out a gasket and stick it in the post ??
Perry
Perry
What about Ralph who was making that mental Metro with a transverse rear mounted V8 and mated it to a Rover FWD gearbox
He also has the necessary machines and watercut stuff to cut them out
I remember seeing a Mini like that. Good for spinning the wheels, but not much else.Ian Anderson wrote:What about Ralph who was making that mental Metro with a transverse rear mounted V8 and mated it to a Rover FWD gearbox
I remember seeing a Mini like that. Good for spinning the wheels, but not much else.Code: Select all
Depends how it´s done. My good friend has stuffed one RV8 into a Clubman, still transverse fwd and eveything fits under the std bonnet. And it drives just like a Mini, apart from a slightly better performance. :lol:
I have a work in progress drawing from when I was going to convert a Rover V8 to Ford MT75 gearbox.
It's been stuck on my online files for years and you can download it from here
http://myweb.tiscali.co.uk/rs2300/rover%20to%20mt75.dwg
If you don't have AutoCad you can download this free software that works a treat.
http://www.3ds.com/products/draftsight/ ... -software/
Original sizes came from a guy on here called 'integerspin' if I remember correctly.
Thanks for your reply.DaveEFI wrote:I dropped it into ProCad+ here and used the dimension finder. That gave the distance between the two bottom holes as 391.91mm. If this is correct (don't think it is) I could easily do the rest. But I prefer DXF files.
The actual tape measure distance from the dowel holes to the crank centre is 184mm.
That dimension on the drawing is over 200mm ??? so I am confused
ooops!
Just tried again and got the same 391.91 as you did to bottom holes.
Tape measure also the same.
So all is well now.
Not sure what I did before.
Thanks for your help.
Regards Denis
I never got to check the Rover sizes, sorry
Intergerspin was on the old V8 forum and I can't find the archive now
From what I have measured on the drawing
Right hand dowel is x+184.85 y 0
Left hand dowel is x-171.64 y+70.44
Ralph85 who posts here would be worth a PM
Mark
Mark
