When I fitted Megasquirt to my flapper 3.5, I replaced the flapper with a bit of tube and fitted the IAT sensor to that. But it seems it may not be the ideal position for a management system that relies on MAP.
Where have others put it?
IAT sensor position
My IAT sensor is in a rubber joiner just before a stainless elbow on the inlet to the plenum, seems to work fine.
I know some IAT's suffer from heat soak, are your exhausts headers nearby?
There is a feature with tuner studio where you can adjust for heat soak with the IAT. Haven't used this though.
What symptoms are you getting with yours?
- SimpleSimon
