Fresh RV8 engine....... What oil should I run?
I know that these were designed to run on mineral oils, and now they have been phased out!! So, my question to you is, what oil should I run in it now??? The engine is going in to a drift car so is probably going to spend most of its life in the top half of the rev range!
Not after theries of, well you need to have this in the oil, but this has been removed from the chemical mix of the oils now, blah blah blah.....
What I'm after is what grade and brand you recomend!
Jono
Jono
- jefferybond
Think Zinc content is a little low on the Halfords Classic 20/50
I have just switched to this one >> http://www.commaoil.com/productsguide/view/6/247
Spec is here >> http://www.commaoil.com/productsguide/f ... 832cfa3a9b
Its cheap compared to others, have a look at the Burton Power website
http://www.burtonpower.com/parts-by-bra ... 20w50.html
Yea, they do still do the GTX, but this is now a semiDaveEFI wrote:Last time I looked they still do GTX.Jono FD3 wrote:I thought the minerals were being replaced by semi now..... just Castrol are reducing their mineral range and haven't seen any in Halfords at all recently!
Jono
