Fresh RV8 engine....... What oil should I run?
Jono FD3
Post by Jono FD3 »
I know that these were designed to run on mineral oils, and now they have been phased out!! So, my question to you is, what oil should I run in it now??? The engine is going in to a drift car so is probably going to spend most of its life in the top half of the rev range!
Not after theries of, well you need to have this in the oil, but this has been removed from the chemical mix of the oils now, blah blah blah.....
What I'm after is what grade and brand you recomend!
Jono
sidecar
Post by sidecar »
I run Valvoline VR1 20-50, it is a mineral oil with a high zinc content which is what the RV8 needs. As it is a 20 grade when cold you need to keep the revs down until it is fully warmed up. (A 10 grade would be better in this respect)
conrod
Post by conrod »
who told you mineral oils have been phased out? plenty on the shelves last time I checked!
From here and elsewhere, you need to make sure it has a high ZDDP (Zinc) content, this is because of the requirements of the cam and lifters. 20W/50 seems to be the majority recommended grade.
Personally, I use Shell Rotella 40 and have not experienced any hassles (yet).
Jono FD3
Post by Jono FD3 »
I thought the minerals were being replaced by semi now..... just Castrol are reducing their mineral range and haven't seen any in Halfords at all recently!
Jono FD3 wrote:I thought the minerals were being replaced by semi now..... just Castrol are reducing their mineral range and haven't seen any in Halfords at all recently!
Last time I looked they still do GTX.
jefferybond
Post by jefferybond »
My old rover v8 likes Halfords Classic 20W-50.
Not sure of the zinc content, but it is designed for older engines, and I think it has a seal swell agent in it to reduce oil leaks.
Jeff
r2d2hp
Post by r2d2hp »
Think Zinc content is a little low on the Halfords Classic 20/50
I have just switched to this one >> http://www.commaoil.com/productsguide/view/6/247
Spec is here >> http://www.commaoil.com/productsguide/f ... 832cfa3a9b
How much is that Comma oil? So many of these products slap a 'classic' label on and double the price...
r2d2hp
Post by r2d2hp »
Its cheap compared to others, have a look at the Burton Power website
http://www.burtonpower.com/parts-by-bra ... 20w50.html
Jono FD3
Post by Jono FD3 »
Yea, they do still do the GTX, but this is now a semi ;) its what I used to use in the RX7 as that was the best mineral oil to use in a rotary.... now it's semi synth I have to spend twice as much on oil :(
Jono
