sump gasket thickness?
Seight-V8
Post by Seight-V8 »
hello all,
Anyone know what thickness the original LR sump gasket is for the 3.5 v8 engine?....
For some reason thicknesses seem to vary.....and the thick ones compress quite altot when the bolts are torqued up....
Went to my local dealer...and could only buy 10 gaskets at £6 so expensive.....
I've bought one from elsewhere...and just want to make sure it aint to thick before i fit it..
Getting sick of changing sump gaskets as they just keep leaking...
scott
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
Hi Scott
Remembering from building the last V8 I think that the gasket is only about 3 maybe 4mm thick at best.
I also had a leak and used a small amount of RTV on the outside edge of a new gasket, bolted it all back up.
No leaks at all after that.
Paul
ged
Post by ged »
Hi Scott,
I glue it to the sump flange with contact adhesive then apply a thin coat of sealant to the other side & lightly coat the block face with oil. This helps you to get it off again.
Regards Ged
Same here!!
Clean the sump flange with thinners to make sure its good and dry. Then glue the cork gasket to the sump. When its fully set it wont move when you nip it up with some hylomar or similar. I have at one time fitted a sump with no gasket and just a bead of "right stuff" gasket seal. That was 2 years ago and the engine is still running with no sump leaks :)
I have also had oil leaking down the threads of the rearmost two bolts (the ones that screw into no. 5 main bearing cap). Some RTV on the threads fixed that.
Seight-V8
Post by Seight-V8 »
cheers all,
When my back decides to let me bend down, i will get around to changing it.
thanks for the help
scott
I have recently had a leaky sump issue.
I have a 4.6 pressed steel sump with which I used a rubber gasket (as supplied with my lower gasket set!)
At first was a bit of a drip which got worse! I the end after 30 miles the whole back edge of the sump was one row of drips.
I dropped the sump to investigate to find the rubber gasket had split and broke in several places so no wonder it was leaking!! (I had torqued up the bolts correctly)
After investigating on this forum I found the Landrover manual says to just use hylosil 101 or 103 with the pressed steel sump, the rubber gasket is used only for the later alu sump.
If it was me for any pressed steel sump now I will just use hylosil 100 series RTV
http://www.hylomar.co.uk/index.php?opti ... &Itemid=75
