Range rover 3.9 no spark??
Hi all
Range rover 3.9 on a j plate
picked it up cheap as a non runner
After cranking it over for a while i can smell a hint of fuel from the tail pipe which sort of says to me that there is fuel getting in but just no spark
It already has a new coil + new plugs, whats the best sequence to be checking + trouble shooting?
James
James
rotor arm???
Right its running
12v at coil when ignition on, but when cranking theres nothing
Put a wire from battery + to coil + and it fired straight up + will keep running when i take the wire away
Any suggestions as to what may be the cause of this?
only thing that spring to mind is ignition switch
Cheers for all the help
James
James
isnt there meant to be a 12v feed from the crank side of the starter solenoid?
check to see if any terminals have come off the solenoid etc,.
Thanks for the replies people
Cheers for the help
James
Any ideas where im likely to find this relay? is there a chance it will be with fuel pump relay?kiwicar wrote:I seem to remember this can be one of the relays that over rides the oil pressure safty cut out while cranking, but I am sure some one will be along to correct me if I am wrong![]()
Will check that todayCoops wrote:isnt there meant to be a 12v feed from the crank side of the starter solenoid?
If you could that would be greatsoftdash3.9 wrote:Mine was a defective rotor arm
The simple RR manual ignition checked identified the faults for me![]()
Haven't got them to hand but could dig them out if you need them
Cheers for the help
James
