rover 4.6 to t5 gearbox
v8 pete
Post by v8 pete »
what clutch plate do i need
mine is slipping need to order a new one
dont have the part number.
hope to order before stripping out engine
What T5 do you have?
The TVR sourced Tremac T5 has different spline size to the Cosworth BW T5.
richardpope50
Post by richardpope50 »
I had the same problem when I swapped from a TVR V8 to an SD1 V8 (temporary reason). I had to use the TVR clutch which is an AP clutch. Therefore you'll need an AP clutch for your 4.6. I would guess you will also need the whole assembly too and may be a bit pricey from TVR sources and as I want to change my plates I was going to try a motor factors but have not done so yet.
There were several numbers on my AP clutch plate but nothing seemed obvious as a part number but it's in my car at the mo so I cannot really read them off at the moment, sorry.
Richard.
seight
Post by seight »
For what it's worth I'm using a CP2394-14 with CP2346-4 from AP which is a 9.5" setup on SD1 (I think) flywheel. Probably overkill in a light car like my Westfield. I think I could probably get away with a 'brown spring' version, my is the 'green spring'. But those part numbers are for the Cosworth T5 box spline, you may need a different plate.
richardpope50
TVRpower.co.uk have clutch options.
Richard.
DEVONMAN
Re: rover 4.6 to t5 gearbox
Post by DEVONMAN »
v8 pete wrote:what clutch plate do i need
You will need to establish which flywheel you are using.
Range Rover or SD1 or TVR etc etc etc
Regards Denis
v8 pete
Post by v8 pete »
flywheel not sure rover i believe [been lightened]
clutch plate is bogr warner 25'4 hole 23 spline 240mm outer dia
must be able to take 270bhp and 260 torque
davehoos
Post by davehoos »
hello
v8 pete
Post by v8 pete »
ordered a ford transit one
and see how that goes
v8 pete
Post by v8 pete »
fitted and seems to work ok
