Im after a wiring diagram of a 3.9 Hotwire ECU plug !
Slatter
Post by Slatter »
Hi guys .. engine is nearly ready to wire up now, however !!!
The loom which im using off the old racer which was purpose made has just got 6 wires coming out that i dont know where to put! i didnt strip the wiring out of the old racer before you all say i should have labelled them!
I have used my multimeter and have established where the wires go to on the ecu plug and relay boxs.
They will be for +ve to fuel pumps and live input in etc etc.
What im after is a diagram of the ecu plug showing where all the wires go to, if you get what i mean.
Any help would be fantastic.
Thanks Slatter
hearbear
Post by hearbear »
http://www.mediafire.com/?byznzniibq0
This is a list of the pin outs on the ecu in PDF format
George
Under Consrtuction
Slatter
Post by Slatter »
Thanks lads :D
