which clutch to use?
oflynno
Post by oflynno »
i intend doing a rv8 3.5 engine to cosworth t5 gearbox project
i have the bell housing
my question is,what clutch do i use?
Re: which clutch to use?
Post by CastleMGBV8 »
oflynno wrote:i intend doing a rv8 3.5 engine to cosworth t5 gearbox project
You can use the Rover SD1 9.5" AP clutch cover but you will need a driven plate to match the gearbox splines of the T5 and fit within the 9.5" cover.
This assumes standard rover flywheel or bolt pattern.
If you talk to AP they should be able to offer you a combination that will work.
By the way there are several different version of the T5 box with different ratios and gear lever positions, what car is is gioing into.
For T5 specific advice you could have a look at this US forum.
http://forum.britishv8.org/list.php?2
oflynno
Post by oflynno »
the engine and box are going into a mk3 cortina
thanks for the link,i will look at it now.
