help with wires please..
Garth84x
Post by Garth84x »
Hi all
just bought a newer dizzy off ebay, and it came with this, can anyone help me with the three wires on the left please as im colour blind, and dont want to bugger it up.
thank you.
Garry
Stu E
Post by Stu E »
The three wires in the plug go to the distributor plug, it will only go together one way.
According to my drawing the wire with the ring is earth the wire next to it on the module should be red and go to 12V the next three wires go to the plug and the last oneviolet goes to the negative side of the coil.
The colours are difficult to see, if you PM me your email I will scan and send you my Lumenition instructions.
HTH Stu.
Darkspeed
Post by Darkspeed »
No purple on that lumi its an older version.
So to keep things simple
Are you sure you meant left !! thats a plug so should be straight forward
If you meant right
Top right - RED - Coil positive - which will also need an ignition Positive/Live connected to it.
Middle Right - Brown - Coil Negative
Bottom Right - Black - Earth/Negative/Chassis
4.5L V8 Ginetta G27
Garth84x
Post by Garth84x »
D'oh !!
yes sorry right in the pic....
Thank you..
Garry
Garth84x
Post by Garth84x »
wired the box up as above, but when i turn the ign off the - on the coils sparks?
any ideas?
