just bought a newer dizzy off ebay, and it came with this, can anyone help me with the three wires on the left please as im colour blind, and dont want to bugger it up.
The three wires in the plug go to the distributor plug, it will only go together one way.
According to my drawing the wire with the ring is earth the wire next to it on the module should be red and go to 12V the next three wires go to the plug and the last oneviolet goes to the negative side of the coil.
The colours are difficult to see, if you PM me your email I will scan and send you my Lumenition instructions.
HTH Stu.
Are you sure you meant left !! thats a plug so should be straight forward
If you meant right
Top right - RED - Coil positive - which will also need an ignition Positive/Live connected to it.
Middle Right - Brown - Coil Negative
Bottom Right - Black - Earth/Negative/Chassis
