how many different types of main bearings do they do for the rover v8?
the first set i got hadnt got any thrust bearings on the the centre bearing and the second set i have got had thrust bearings on the centre but top and bottom
my engine just has the 1 half (block side) that has thrusts on and the number 3 cap has the same bearings as the other 4
i thought the lower half of the thrust might fit but it wont as the tang is off set on it and the main bearing cap is central
im going to go back tomorrow but thought you guys might lead me in the right direction
Si
Main Bearings?
- Pocket rocket
The centre main bearing is the thrust bearing. It's only the block-half of the bearing that has the thrust faces on it on later (large journal) engines. I'm not sure about earlier engines.
But at least one of the shells on the centre bearing must have thrust faces!
