Main Bearings?
toger13
Main Bearings?
Post by toger13 »
how many different types of main bearings do they do for the rover v8?
the first set i got hadnt got any thrust bearings on the the centre bearing and the second set i have got had thrust bearings on the centre but top and bottom
my engine just has the 1 half (block side) that has thrusts on and the number 3 cap has the same bearings as the other 4
i thought the lower half of the thrust might fit but it wont as the tang is off set on it and the main bearing cap is central
im going to go back tomorrow but thought you guys might lead me in the right direction
Si
toger13
Post by toger13 »
its a 3.9 efi out of a 98 discovery auto by the way
Si
Pocket rocket
Post by Pocket rocket »
What is the engine number of your block? That might help someone to answer your Q.
Is the main cap in question machined to take a thrust washer?
The centre main bearing is the thrust bearing. It's only the block-half of the bearing that has the thrust faces on it on later (large journal) engines. I'm not sure about earlier engines.
But at least one of the shells on the centre bearing must have thrust faces!
toger13
Post by toger13 »
they think they should have the correct ones tomorrow
the origanal ones i got were to engine number and were nothing like right didnt even have thrusts at all
guy at 4+ said it was quite common that parts ordered to engine number didnt fit they were genuine Landrover ones too lol
Si
toger13
Post by toger13 »
6 sets of bearings and still no joy :(
hopefully real steel will pull it out of the bag on tuesday im feeling confident as he knew about this problem has seen it before :D
Si
