running in oil
Seight-V8
running in oil
Post by Seight-V8 »
hiya all,
question is....
running in oil....or normal oil + break in additive.
For the initial start up and running of a 4.6 engine???
need to make a decision...but the subject of oil is a big question.
scott
sidecar
Re: running in oil
Post by sidecar »
Seight-V8 wrote:hiya all,
question is....
scott
I had the same worries when I built my 4.6, I posted up on the Cobra forum and got a few suggestions in the end I stuck Valvoline VR1 20-50 in it to run it in. I still run with it now. (Not the same oil, I did change it!)
Pete
poo slinger
Post by poo slinger »
i got told u mite aswell use old oil as your not going to be using the engine hard and its only guna be changed.
sidecar
Post by sidecar »
poo slinger wrote:i got told u mite aswell use old oil as your not going to be using the engine hard and its only guna be changed.
I know where your coming from but some bods on the cobra forum pointed out that the inital startup put the most strain on the bearings and the cam even when you prime the system, during this time why would you want to put a low quality oil in it and risk wiping out a cam etc. (You still need to use cam lube whatever oil you use)
What you should not do is run it on a synthetic oil as the rings won't bed in.
VR1 is quite expensive considering that you will though it away after a 100 miles or so but in the end I bunged it in anyway.
In fact I went to extreme lengths during my first start up.
I primed the system then rotated the crank 1/2 a turn and primed the system again, I repeated this for 2 full turns of the crank.
I filled the sump before I fitted the valley gasket, I used a funnel so that I could direct the oil away from the cam lobes, this was to prevent the oil washing the cam lube off the cam.
I ran the cam in for 25 minute in two sessions, at around 2K RPM, during this time my mate sprayed the rad with a hosepipe to keep the temperature around 70 degrees.
The motor was fired up with the coolant cap off, the coolant was topped up as the level dropped, as soon as it would not take anymore the cap was fitted.
You can see that really 3 people are needed to carry out the above.
I spent ages building this motor, there was no way that I was going to knacker it with a dodgy start up!
ged
Post by ged »
I used a similar method for priming, had the girlfriend on primer duty with the drill while i slowly turned it over via the crank bolt.
not gona be that easy for me with a crank driven oil pump :-(
anyone know if there is a way to prime a dry crank driven pump?
A crank driven style are usually designed better than the old Rover pump. Just fill it with oil when building, and it should prime just fine on the starter.
Millers do a specific running in oil.
RoverP6B
Post by RoverP6B »
When my 4.6 was built, Penrite "running in" oil was used for the first 700km.
The oil is a 20w-50 specification with additional quantities of the necessary ZDDP to ensure that the camshaft runs in properly.
The distributor was removed, the magic wand used on the end of a drill to run the pump and run the oil throughout the engine, refitted and away we go.
Ron.
4.6 Rover 3500 P6B
SC500
Post by SC500 »
thev8kid wrote:not gona be that easy for me with a crank driven oil pump :-(
Vaseline :wink:
Supercharged 5ltr TVR Chimaera now with Intercooler
www.sc-power.co.uk for vids and pics
bugger,
its all fitted on the engine now :?
looks like a bit of cranking over me thinks,
it will still pump up wont it?
how about if i pour a some oil into the pump so it has something to work on?
i use to use vaseline on the old dizzy driven pumps,
topcatcustom
Post by topcatcustom »
I'd just crank it over without the spark plugs connected, you should get oil pressure pretty quick
SC500
Post by SC500 »
Otherwise there is another trick about squirting oil up the oil filter housing.
Here it is:
Drain the oil and unscrew the oil filter
Take a small bottle with a pipe that connects to the top of the bottle
Fill the bottle with oil and stick the pipe into the threaded part of the pump that the oil filter screws into.
Squeeze the bottle and press oil into the pump.
After some time oil will come out of the other hole of the filter mounting.
Keep squeezing for 20 seconds
Replace the pre-filled oil filter and top up the oil
Start the engine and check for oil pressure and then for leaks.
Link: http://www.gomog.com/allmorgan/plus8oil.htm
SC500
Post by SC500 »
Thought I would just drop a little link here with the millers oils that we offer which includes a running in oil.
10% off to V8 owners forum users:
http://sc-power.co.uk/SC%20Power-millers-oil.html
