Just purchased engine Number 11A62600 which has got the apparent following problem. "Ignition system keeps destroying the coil over a period of time. It has used three coils before being removed."
Any ideas what might be the problem - seller said the distributor needs replacing to solve it. Also what distributor and carbs should be fitted to this motor.
CY2010
Engine troubles
