Weight of a block
TVRleigh
Weight of a block
Post by TVRleigh »
Weight of a block. idealy a Xbolted but don't think it was vary that much.
Idealy within 5kg
anyone know the aprox weight of a block, with liners but without pistons or crank, but with end caps.
no heads or sump.
thanks
Leigh
JSF55
Post by JSF55 »
10-15 kgs at a guess, there not that heavy .. unlike trying to get it off the bench after u've assembled the bottom end !
So thats where it went !
Post by ian.stewart »
If I can sneak the bathroom scale up the grage tomorrow, I will weigh my 3.5, its a bit easier to sneak out the scales than to sneak the block into the barhroom!!!!
Or the other weight calculation is, its not too heavy so I cant lift it above my head, but damn heavy enough to hurt when you drop it in your foot.. :shock: :shock:
HairbearTE
Post by HairbearTE »
A bare X-bolt is around 35kgs I believe. Earlier blocks are a little lighter.
kokkolanpoika
Post by kokkolanpoika »
http://www.v-8.org.uk/forum/viewtopic.p ... highlight=
I weight almoust all pars what i have..
Bare block 94mm bore, inc bearings carrier + bolts is near 34Kg +-1Kg. Total 33-35Kg :lol:
I think 35Kg is absolute maxium..
Timo
TVRleigh
Post by TVRleigh »
Thank you.
I was thinking it was between 25 and 40. so 35 sounds right.
JSF55
Post by JSF55 »
I must be stronger than i think :lol:
