Weight of a block. idealy a Xbolted but don't think it was vary that much.
Idealy within 5kg
anyone know the aprox weight of a block, with liners but without pistons or crank, but with end caps.
no heads or sump.
thanks
Leigh
Weight of a block
Weight of a block
Current V8 car TVR 400SE 240 BHP
Current Project TVR Tasmin Race, with 3.9 running at 230 BHP
Currently building a 4.6 300 BHP Xbolted Engine for it. Solid Lifters and Group A rockers, Stange 4 heads, Pocketed piston, fully balanced.
If I can sneak the bathroom scale up the grage tomorrow, I will weigh my 3.5, its a bit easier to sneak out the scales than to sneak the block into the barhroom!!!!
Or the other weight calculation is, its not too heavy so I cant lift it above my head, but damn heavy enough to hurt when you drop it in your foot..
THE SMOKING GNU
- HairbearTE
- Guru
kokkolanpoika
- Knows His Stuff
http://www.v-8.org.uk/forum/viewtopic.p ... highlight=
I weight almoust all pars what i have..
Bare block 94mm bore, inc bearings carrier + bolts is near 34Kg +-1Kg. Total 33-35Kg
I think 35Kg is absolute maxium..
Timo
Thank you.
I was thinking it was between 25 and 40. so 35 sounds right.
