i'm looking at changing my pistons from 8.13 to 9.25 :1 ...is it just the pistons that are differant ?
and is there any marking on the pistons to tell which is which ?
thankyou
compression ratio
Personally I wouldn't use second hand pistons from another engine but yes it could be done. If you really have to go this route then I would advise you match the pistons to bore as best as you can. Old pistons from another engine will never give you the the best clearances but if needs must. Rod wise use your own rods, it makes no odds when you change the shells.
