compression ratio
bodger
compression ratio
Post by bodger »
i'm looking at changing my pistons from 8.13 to 9.25 :1 ...is it just the pistons that are differant ?
and is there any marking on the pistons to tell which is which ?
thankyou
katanaman
Post by katanaman »
Other than the newer 4.6/4.0 heads having a smaller combustion chamber yes its just the pistons. Its easy to tell the pistons apart because of the dish which is visibly deeper on the low comp pistons.
bodger
Post by bodger »
thankyou , would it be ok to stick pistons from another engine in mine ??????
i will put new rings on and lightly hone the bores first
and shall i use the rods that come with the pistons or use my existing ones , i will be putting news shells in while it's apart anyway for the sake of £18 quid
katanaman
Post by katanaman »
Personally I wouldn't use second hand pistons from another engine but yes it could be done. If you really have to go this route then I would advise you match the pistons to bore as best as you can. Old pistons from another engine will never give you the the best clearances but if needs must. Rod wise use your own rods, it makes no odds when you change the shells.
