SD1 Flywheel weight.
Yes its a standard SD1 unit.
I was hopping I could fit a trigger wheel too it, but look like it will be a lot of work.
Just weighed mine tonight, had to lug it up a flight and a half of stairs to my flat, now if I had a brain I would have taken the scales down to the car!
Anyway it weighs in at 28 1/2 lb I knew it had been lightened and balanced but didn't know what the original weight was, not too light and should go well with the new engine.
Weighed mine also,
Standard SD1 was 31lb aprox.
I think lightened are normaly 27lb 4lb lighter.
ian.stewart Can I ask where you got your flywheel from and how much it was.
Leigh.
Leigh.
