I've sheared the lower right long water pump bolt on the '72 3.5 out of my P6B. It has broken off a couple of mm into the water pump casing. How do I get the remainder of the long bolt out now?
Grateful fur any advice gentlemen.
Do you mean it is broken off on the thread inside the casting it screws into? If so you might have to do the old accurately-used-small-drill trick and work up in size until you can pick the remains of the thread out. Or use an Eazyout once you have a hole drilled in it.al mackenzie wrote:![]()
