I'm waking up my TVR 350i (RV8 with flapper) after a long rest, the temperature gauge isn't working but the fuel gauge is (both VDO gauges). The single wire to the temperature gauge sensor in the block measures as 7v when disconnected from the sensor (this isn't the temperature sensor for the ECU or the temperature sensor for the 9th injector). If I ground the wire the gauge doesn't move
What is the stabilised voltage for instruments on a TVR 350i? My guess is 10v.
I'm using this useful diagram as posted elsewhere on this forum:
