Help. Pics Needed
need4speed
Help. Pics Needed
Post by need4speed »
My Hotwire plenum had a load of cruise-control gubbins that was getting in the way of my intake hose so I removed it all.
Could someone possibly show me some pics of the simplest possible throttle cable setup with least amount of parts?
Thanks.
need4speed
No-one huh
need4speed wrote:No-one huh
Could be that removing the cruise control should leave the throttle working normally? It does on my SD1.
need4speed
No. On removing the bulky cruise gubbins it also removed the throttle assy as well. It seemed to be 1 unit. That's why I was asking for some pics so I could see if I've done something wrong..
Well, bits from an SD1 EFI will fit your plenum. The usual cable from there to the pedal. Or the bits from a hotwire without cruise?
I've not really seen a hotwire cruise. On the SD1 EFI, the cruise motor simply unclips from the throttle lever.
DaveEFI wrote:I've not really seen a hotwire cruise. On the SD1 EFI, the cruise motor simply unclips from the throttle lever.
My P38's cruise is the old fashioned bellows and cable set-up with a vacuum pump instead of manifold supply to improve control.
Yup - sounds like the Hella system fitted to later SD1.
JSF55
Post by JSF55 »
Imagefuel lines on by john fraser, on Flickr
Imagecut down linkage 1 by john fraser, on Flickr
Do these help any ?
So thats where it went !
About half way down this page, http://www.cowdery.org.uk/miscv8.php is a few pictures of the GEMS manifold, one from an SD1 and the later 4.6 one.
need4speed
JSF55 wrote:Imagefuel lines on by john fraser, on Flickr
Do these help any ?
John that looks like a nice compact setup compared to mine. Are those standard sd1 parts?
JSF55
Post by JSF55 »
They might have been range/land rover parts if it makes a difference ? but it was just trimmed to suit a few plates added for cable holes, I was running auto and needed a kickdown position too
