Help. Pics Needed
- Getting There
Help. Pics Needed
My Hotwire plenum had a load of cruise-control gubbins that was getting in the way of my intake hose so I removed it all.
Could someone possibly show me some pics of the simplest possible throttle cable setup with least amount of parts?
Thanks.
Thanks.
- Getting There
Well, bits from an SD1 EFI will fit your plenum. The usual cable from there to the pedal. Or the bits from a hotwire without cruise?
I've not really seen a hotwire cruise. On the SD1 EFI, the cruise motor simply unclips from the throttle lever.
Yup - sounds like the Hella system fitted to later SD1.unstable load wrote:My P38's cruise is the old fashioned bellows and cable set-up with a vacuum pump instead of manifold supply to improve control.DaveEFI wrote:I've not really seen a hotwire cruise. On the SD1 EFI, the cruise motor simply unclips from the throttle lever.
Do these help any ?
So thats where it went !
About half way down this page, http://www.cowdery.org.uk/miscv8.php is a few pictures of the GEMS manifold, one from an SD1 and the later 4.6 one.
- Getting There
John that looks like a nice compact setup compared to mine. Are those standard sd1 parts?JSF55 wrote:fuel lines on by john fraser, on Flickr
cut down linkage 1 by john fraser, on Flickr
Do these help any ?
