On the principle of doing one thing at a time, I was hoping to first change to hotwire high impedance injectors as the Vitesse low impedance ones cant be used with the later MS injector drivers, without also using resistors, which I got rid of. And get a reasonable tune with them on batch injection before changing the wiring loom, etc, and going sequential. Also going the change the fast idle arrangements.
I hadn't noticed that the injector holes in the manifold are different between the two types, as well as the fuel rail. And that the later fuel rail fouls the CTS on the flapper manifold.
So it looks like it is going to be easier to change the manifold as it would have to come off anyway to modify the injector holes.
I have four different assorted ones here.
Looks to be like a Gems one may be the best bet - it has a heater feed which the hotwire doesn't, and should be quite easy to plumb in. My Vitesse heater feed comes from the back of the thermostat housing and runs underneath the manifold. A PITA if it leaks.
This is a pic of the one I'm intending using - I think it is Gems.
It had no thermostat in the usual place - but looks like one can be fitted using the SD1 elbow.
Any obvious gotchas I'm missing? Are the internal waterways the same?
