hey guys ,
question is .......
i have a home build project with a 3.5 was running points but i swapped the points out for a electronic ebay special which lasted a few week
ive wired the coil direct to the ign it has a 3ohm resistor in but it still blew it and the module is fried too
i want to change this out to a full electronic sysytem
can i fit a 3.9 dizzy / ign amp and if yes how would i wire it since i only have 1 wire into my engine bay lol
any info would be great thanks
Wiring dizzys and ignition amps
3500 VWt25
That would be a good choice. You then have a distributor, amplifier and coil that are all matched.
You just need to power the coil positive with +12V. The amplifier will then have two wires to the coil and two to the distributor (unless it's the amplifier that fixes to the side of the distributor). And away you go!
3500 VWt25
Lost :-(
Okay so I bought that set up linked above ,
Question is the dizzy had a two pin connector and the ignition amp had a 3 pin connector
Is there like a link cable missing from this set up
3500 VWt25
cheers dave the set up i was sent had a defective vac advance ,
so ive been sent another dizzy set up
it has the ign mod on the side of the dizzy and two spade connectors ,
im right in thinking one goes to coil v- the other v+
do i need a balast resistor on both set ups or am i better off swapping the vac units over
thanks in advance
craig
thanks in advance
craig
