I've Stromberg cd175's on my Land Rover 101. I'm having to frequently top up the damper oil in both carbs. IE usually after each run of any distance of more than about 20 miles approximately, it has dropped really low. The engine then starts to misfire under medium to heavy acceleration.
I can't see any obvious signs of leaks and both diaphragms have recently been renewed.
Any suggestions would be most appreciated
Regards
Jim
Carb damper oil disappearing
do you have an arrangement to lift the pistons to the top of their travel when you switch to lpg? If so then it is sucking the oil out the dash pots because air is being drawn in through the little hole in the top of the dash-pot and displacing the oil as it passes into the space above the diaphragm.
best regards
best regards
