Carb damper oil disappearing
jimland74
Post by jimland74 »
I've Stromberg cd175's on my Land Rover 101. I'm having to frequently top up the damper oil in both carbs. IE usually after each run of any distance of more than about 20 miles approximately, it has dropped really low. The engine then starts to misfire under medium to heavy acceleration.
I can't see any obvious signs of leaks and both diaphragms have recently been renewed.
Any suggestions would be most appreciated
Regards
Jim
Owner of a Land Rover 101 GS V8 with LPG
do you have an arrangement to lift the pistons to the top of their travel when you switch to lpg? If so then it is sucking the oil out the dash pots because air is being drawn in through the little hole in the top of the dash-pot and displacing the oil as it passes into the space above the diaphragm.
best regards
jimland74
Post by jimland74 »
Regards
as I'm aware, no. I don't think so. What would such an arrangement look like Chris?
Regards
Jim
jimland74
Post by jimland74 »
Sorry. Meant Mike, not Chris
doh!
Your carbs will have an extra pipe like this:
(those are 2" SU's, but same idea)
jimland74
Post by jimland74 »
No I don't have these pipes. Only have a pipe at the lower part of each carb to feed the LPG in
sorry no idea then, never heard of LPG being fed straight into the carb.
best regards
