I'm building a new Rover V8 around a 3.9 block and Buick 300 crank. I was planning to go down the Ford piston / Chevy rod route, but now I've been told that it's possible to use Rover rods with cut-down low compression R/Rover pistons - apparently there's supposed to be enough meat in the crowns to machine down.
Has anyone done this before, or is this a load of ****??
Thanks for a great forum,
Snakey
Pistons for a Buick 300 crank
not a hope there is no way you can take that much off. Top of the crown is the same whether it is low comp or high so far as I now anyway.
Just looked up the strokes
3.9 is 2.800"
4.2 is 3.000"
300 is 3.380"
so 3.9 pistons would need 7.36mm removed
4.2 pistons would be 4.826mm which is still too much.
3.9 is 2.800"
4.2 is 3.000"
300 is 3.380"
