Great meeting you at the weekend although I missed all your passes. Good to catch up with Mike again. as always a fraught start to the weekend we really need somewhere to fire the car before we load it.
Anyway from a 120 main and a 65 high speed open all the time
we went to a 110 main and no high speed and it wasn't a slobbering idiot! Ran a 9.38 with a 1.35 60 ft and the plugs said it needed more fuel. Went to a 105 and ran 9.35 with a 1.33 60 ft, went to 100 pill and activated the high speed with a 50 in it and ran 9.37 with a 1.35 60ft, more missing at the top on this run, there was a bad misfire past half track every pass but we were concentrating on the bottom end. For the final pass we left the 100 main alone and went to 65 on the high speed and the car responded with a 1.30 60ft and 9.3035 on our 9.30 dial in, next pass someone went 9.2033 on a 9.20 to take away the closest to dial trophy by 2/10,000 of a second. Happy days we have found we can put a ton of fuel low down and the engine is not unhappy, can play with the high speed to get the mph back up into the 140's, we ran 139 three times and 135 on the 9.37 when the miss was at its worst, just laying over rich as we run out of headflow down the track. Plugs look great and no damage. If we can just cure the oil pump priming issues we will be in good shape.
Alan
