Is my cooling layout correct - Pic Attached
Loz V8 Capri
Post by Loz V8 Capri »
Hello all,
I honestly thought this would be so easy (I should know by now)....
Having recently changed the engine in my car I find myself having some cooling issues (steam from cap). I'm confident it might have something to do with my water pipe set-up.
I have an edelbrock performer intake, a thermostat housing with the extra by-pass attachment, an expansion tank from a rover, a radiator from an audi (no cap) and a P6 water pump.
I've searched multiple web sites for answers but seem to find contradicting suggestions...
Hope my diagram makes sense. Please help, its extremely frustrating
https://www.dropbox.com/s/3qpuut5o62h2o35/SDC10408.JPG
'Feels like giving up 99% of the time'
Loz V8 Capri
Sorry, its a header tank...
What exactly is the problem ?
The diagram looks pretty good really.
Only bit not 100% sure about is the one from stat housing to pump.
The heater would normally circulate hot water that never goes through the stat. Maybe it's just the drawing though.
Denis247
Post by Denis247 »
Almost exactly identical to my setup, except I have an extra filler cap in my top hose run. I've had this in my Lotus for years now with no problems, maybe you have a faulty component, or slipping belt (assuming it's an overheating problem you have).
Loz V8 Capri
Thanks for your replies. My problem is that its overheating and pretty quick too. I get about 7 miles down the road and it starts to vent from the header tank cap.
I will check my belt but Im sure its ok...
Is water circulating ok, start opening etc ?
Proper airflow through the rad ?
Darkspeed
Post by Darkspeed »
No the connection to the expansion tank is incorrect as the top of the hose to the rad is a low pressure point - the small hose to the expansion tank must be from a permanent high pressure point the other side of the stat.
Also I know its just diagramatic but the connect from the expansion to the pump should be as close to the pump as possible.
4.5L V8 Ginetta G27
I think it is fine, provided the small pipe from the top hose to the heater tank has a pipe inside the header tank taking it to somewhere near the bottom of the tank.
Anyway, is it definitely overheating?, you can see on the gauge?
Loz V8 Capri
yeah, he's over heating. Gauge reads high and it steam out / boils over pretty quickly. Thinking of trying another header tank as this ones from a Volvo...?
SO is the water pump actually working and water circulating through the rad properly ?
And the rad cooling the water ?
Return to “Cooling Area”
