A big difference, the spark is mutch brighter and starting is much better.
Even today 1 clik and vrooooaaaam it also idles much better !!
( start on lpg no gas tank anymore)
I always thougt that a coil could not become weak just broke.
Do you have standard Rover ignition otherwise?Steven 90 wrote:I fitted a new coil from http://www.simonbbc.com/powerspark-ignition-coil
Even today 1 clik and vrooooaaaam it also idles much better !!![]()
Their site says:-mgbv8 wrote:I give Simon a big thumbs up for his stuff.
Yes i had, now i am fitting megajolt.jimbob wrote:Do you have standard Rover ignition otherwise?Steven 90 wrote:I fitted a new coil from http://www.simonbbc.com/powerspark-ignition-coil
If it's a Smiths, they seem to very variable as to how they react to input pulses.Johnny Rotton wrote:I fitted a new Lucas coil and distributor supplied by Powerspark last year and the car has run fine since. However, the rev counter is over reading higher up the rev range and the needle is very erratic. This was after fitting the new coil and dizzy (35DLM8). Any thoughts ?
