Clutch + Flywheel advice for LT77 to 4.6 Gems
mcc1979ian
Post by mcc1979ian »
ok so iv finally got the 4.6 gems engine in the garage and the LT77 is ment to be coming today, now the question is which clutch and flywheel should i be running
the 4.6 was attached to an automatic so im assuming that im going to have to change the flywheel for a manual one
clutch, well i honestly i havent a clue which to fit
all help much appreciated
p.s if you could post a link to the parts that would be amazing
thanks as always
Check if there's spigot bush in the end of the crankshaft, you need one if not.
mcc1979ian
need a spigot bush or flywheel
Your easiest option is to get flywheel / clutch etc from an SD1 (presuming that's what the LT77 came from).
If the LT77 came from a Range Rover, then get the flywheel / clutch assembly from one of those.
The engines are all the same as far as crankshaft / gearbox mating flange goes. Just the auto ones didn't get a spigot bush in the end of the crankshaft.
