Fuel Hose,
Fuel Hose,
Just need someone to confirm what im already thinking,
Is it ok to use rubber fuel hose on the pressure side of the efi system :?: :?:
been working on mine tonight as i could smell fuel while driving the weekend,and noticed the o ring joints on my plastic fuel hose are all weeping, i plan to replace the plastic hose with rubber hose if that is ok to do away with all the joints and to tidy it all up,
Post by ian.stewart »
In a word, NO, you must use Injection quality braided hose, even with the correct stuff I have found with the slightest nick in the braiding the hose will baloon, for this reason alone, I went to SS Braided hose
THE SMOKING GNU
bugger
looks like the car is going no where this weekend then :(
Tony
Contact Think Auto
http://www.thinkauto.com/
they do a large amount of hose including stainless outer braid - will make up hoses to spec if desired or can supply everything for you to put it together
Supposedly same day dispatch but never checked that as I'm close enough to collect
This is the hose we use at work, and what i thought about using,
the hose is supplied by Wurth,
landybob_v8
Post by landybob_v8 »
thats what ive used for mine tone ive also covered it in the plastic wrap used on wiring looms (type that has a big wrap and a small wrap that lock into each other to protect it)
seems to work fine for me
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
Tony, do a google on the spec and see what comes up
THE SMOKING GNU
i can't find any info mate,
you had any joy?
http://www.wurth.com.au/catalogueview.a ... 4_0241.pdf
found this, looks like we have an old batch of hose.
