I have just built an engine for my mates 205, based on a 306GTi6 lump, made 240bhp and 193lb/ft probably only cost £2.5k.. Damn these germans...
BMW 4.4ltr V8 into E36 Saloon..!
Are yes very under rated, but how much is a cam kit for your ford, bet its not £1000 ish, pair of gasflowed heads £2500 ish, I wish it was as cheap to modify as a ford or small block chevy........... It would have alot more power if I could afford it...
Interesting install mate! well done..
What management did you use in the end?
Who was the company made your flywheel for you? also if you dont mind me asking how much did it cost?
How is your clutch holding out?
Also do you know if the manual gearbox of an M60 v8 will fit the M62 v8 engine?
I have found an Engine, and think i might have found a gearbox!
Finding a complete e39 540i Manual car is proving impossible to get.
Thanks for the information.
I don't know if its mine in the mag haven't seen it, me and Dave were talking about bigger engines, its always been the case that there is no substitute for cubic inches, the old problem was that big capacity came with big weight but not any more, my BMW V8 weigh's the same is the american version of the straight six and with multi valve units out good power outputs can be achieved with very little modification....
Steve.
Steve.
My project is still underway with the same unit and 6speed box.. have you considered any more power mods? at the moment its just decatted and remapped? 340hp?BMWE36V8 wrote:Hi,
Steve.
Can i have the contact details for the company who modified your oil pump?
I agree Chris, the rover v8 was and still is an excellent engine and very light..!! Had one in a cortina MK5 and MK3 capri..
I am in the throws of fitting individual throttle bodies on her, should give it a bit more.... and as for the oil pump, I have the one and only jig for holding everything inline for welding the extension pieces in place.....
Would you be willing to lend it or get a pump modified for me?BMWE36V8 wrote:I agree Chris, the rover v8 was and still is an excellent engine and very light..!! Had one in a cortina MK5 and MK3 capri..
