Check the entire thread.truckdoctor wrote:located the width of an sdi and its 62 inches between wheel mounting faces which is OK but the lowest ratio as far as I can find out is 3.09.
Not sure if 2.7 is available though . Is this correct?
Auto injection SD1s (Vitesse, EFI) had a 2.85 ratio. But only those two, which makes that axle quite rare, as most Vitesse are manual, and there were only about 1000 EFIs made.
And as I said, I know where there is one for sale for £100.
