4.6 block??
minter
4.6 block??
Post by minter »
hi guys wanting some advice,,,
currently running a blown 3.5 rover,, i'm very keen on making more hp/torque etc,, the easiest way for me to do that is buy buying a 4.6 block building bottom end then transferring top half of 3.5 over.
i'm always told the 4.6 is always prone to faults leaky liners etc,, should i be looking at something like this with block having top hat liners, x bolted mains etc
http://cgi.ebay.co.uk/RANGE-ROVER-P38-V ... 43a0fd63e5
will this eliminate the problems prone with these blocks?
i wanna go chevy route eventually but this the best fastest option for now.
your thoughts please,, many thanks.
The top-hat liners certainly cure the symptom of a crack behind the liner. The block remains cracked of course, but that doesn't seem to matter.
£1250 seems a little steep for just the block to me, you can have a reconditioned chevy 350 4 bolt long engine from real steel for £150 more but I supose its not a rover.
best regards
Turner Engineering are about £1300 I think, and they O-ring the bottom of the new liner.
The cheaper vendors (£800 ish) just stick a wadge of silicone sealant there instead.
Not sure which method this vendor uses.
kokkolanpoika
Post by kokkolanpoika »
Just wondering is it bossible to bore Turner Engineering block to 96mm bore, if they use O-ring at the bottom?
When my local machine shop in Finland made couple of top hat blocks, i think they only add some glue between the block/liner, not silicone selaer?
And i dont have any proplem + ever hear any bad for other blocks..
V8 developments sell top hat blocks at 995inc vat?
Timo
POAH
Post by POAH »
kiwicar wrote:£1250 seems a little steep for just the block to me, you can have a reconditioned chevy 350 4 bolt long engine from real steel for £150 more but I supose its not a rover.
best regards
yeah but look who is selling it lol
katanaman
Post by katanaman »
FFS it was only a couple of weeks ago he told a forum member the top hat blocks were rubbish and the only thing to do was buy one of his Coscast blocks! I guess he has ran out of them for the moment!!!!!
Not sure it's the same 'entrepreneur'!!
katanaman
Post by katanaman »
You might be right Chris I am not completely sure now you mention it.
katanaman
Post by katanaman »
In fact you are right, I know who it is now.
ged
Post by ged »
Have you checked out the company name in contact details? Image :lol:
minter
Post by minter »
are these companies just for the work on the block or do they do hole bottom end?
best regards
In my experience Real Steel are pretty well respected certainly I have had very good service from them and find their prices good. Are you thinking of RPI by any chance??
I to had the same idea over a year ago now!
I had a 3.5 supercharged and wanted more... Found a 4.6 on e-bay thought it was worth a gamble. Paid £300 for block bottom end and heads. Had been in a vehicle fire apparently???
Anyway had the block pressure tested and three liners leaked :( but I brought it knowing this was a posible. Think it was £800 for top hat liners. I won't get into the new gearbox to handle the extra torque, new diff with a more suitable ratio, new fuel system (pump,injectors) etc,etc...
When boring the new liners they asked what size? So then I started dreaming about going bigger... but had to stop myself getting carried away as funds wouldn't stretch to new pistons and balancing as well, so i'm making do with supercharging my 4.6. :D
minter
Post by minter »
SuperV8 wrote:I to had the same idea over a year ago now!
hi tom yes i'm very keen on going bigger,, i'm pretty suprised wiv performance now from a 3.5 wiv blower,, have u had a dyno with the 4.6 hp torque?? who dun the work on your block,, deciding which way to go about it?!?
