What kind of taxes would I pay ?
Thanks for any info
Mark
why not talk to them and say you would rather get one from the UkMark wrote:So I'm looking at approx £1230, might be worth 'phoning Real Steel and seeing if their gold discount card applies to gearboxes ?
Mark
something like that.Ian Anderson wrote:From memory duty is 5%
But they charge import VAT too at 17.5%
You'll also get charged an admin feeby TNT or whoever
I'd bank on a total of 25% and expect some change back
I will be fitting a 302 Ford into a Sierra and hoping to get some half decent mpg on a run with the high top gear. The guy I bought my 7 1/2" cossie diff from ran one in a tuned 289 Sierra and said it pulled top gear no problems.CastleMGBV8 wrote:Mark,
Summit Racing have them at $1295 + shipping so may worth checking out.
http://www.summitracing.com/search/Prod ... toview=SKU
What car and engine do you intend mating this to?
I would also ask if you haven't already, what the ratios are for this box as T5's vary by quite a lot, most come with an extremely high 5th at 0.63/1 which to high for performance use, the super duty may have a more sensible ratio of around 0.8/1
There are also differences between the chevy and ford versions in terms of the shifter/gear lever position and angle of the gearbox in the car.
Have you sourced a bell housing?
