just checking , are all SD1 V8 alternator brackets the same i.e will an alternator bracket from a series 1 fit my Vitesse,
cheers
sd1 alternator bracket
I assume my EFI being a late model has the latest one - the alternator hangs from it. And it has broken twice.jrv8 wrote:Hi ,
There's two different styles of SD1 V8 alternator bracket, but they have the same mounting points and also the same spacing for the alternator, which hangs below the bracket.
Either type of SD1 bracket will be ok , as they are fully interchangeable.
Regards
Jim
The early type has a flat top with more alloy in it , and does tend to be the stronger of the two.DaveEFI wrote: I assume my EFI being a late model has the latest one - the alternator hangs from it. And it has broken twice.
They don't break that often, is your alternator alignment ok ?
Jim
www.jrv8.co.uk
As it came from the factory - so unlikely.jrv8 wrote:The early type has a flat top with more alloy in it , and does tend to be the stronger of the two.DaveEFI wrote: I assume my EFI being a late model has the latest one - the alternator hangs from it. And it has broken twice.
Jim
www.jrv8.co.uk
