Just looking on e-bay at engine stands as I'm finaly getting close to assembling the new engine. Just wondered if anyone has one of the sealy stands and what model/size? I just want a basic (read cheap ) but dont want to get one thats too small to fit my RV8!
Hi Brian
I got a cheapie Machine Mart one, the u-shape base type, figured that would be more stable than the "t" shaped ones. Had a fat old Chevy hanging off it no problems.
I've got a really cheep T shaped base one with a big fat SBC on it (machine mart from what I remember), it is fine provided you try and get the block centre of gravity aligned with the pivot that lets you rotate it, it is well worth the time to set it up right.
Sealey ES450 Engine Stand 450kg
This engine stand accepts a wide variety of engines and transmissions. The head swivels 360º for accessibility to all parts of the engine. Fully adjustable mounting arms. Swivel castors provide excellent manoeuvrability.
• 450kg Capacity.
• Accepts wide variety of engines and transmissions.
• Head swivels through 360°.
• Swivel castors for easy manoeuvrability.
• Fully adjustable mounting arms.
• Model No. ES450
I got the cheap T shaped one, but I modified it with a stabiliser bar to turn it into an H shape. It really helps as when torque up the mains etc it holds it steady whereas before it would try to tip over. You can see it in this pic, didn't realise how much its changed in there this is a year old!
topcatproduction wrote:I got the cheap T shaped one, but I modified it with a stabiliser bar to turn it into an H shape. It really helps as when torque up the mains etc it holds it steady whereas before it would try to tip over. You can see it in this pic, didn't realise how much its changed in there this is a year old!
That looks about the same as mine, Got a drip tray that fits along the spine, the thing is attached to the stand using U shaped fence pannel clips,
THE SMOKING GNU
