crankcase ventilation problem
I've seen this with rising rate ones set to approx 36 psi before. Think they are really designed to work at a much higher pressure. And the spring pressure on the diaphragm forms the one way valve. But they are simple devices to take apart and check for damage or dirt.richy wrote:hi Dave,hi Dave,i done some tests,i clamped of the fuel return pipe and it holds the fuel pressure.does this mean my new fuel (FPR) is faulty,thanks.richy
