Finally got engine running but can`t select any gears, have heard of this happening before so if anyone can give me a bit of advice it would be greatful.
Series 3 Land Rover with 3.5 V8 Rangie engine on standard series box.
Chris
Got no gears !!!!!!!!!
Sounds like what happened when I fitted a v8 to my series 3. Have you taken the little cover off the bellhousing on the front of the gearlever to see what the clutch is doing? Does the clutch pedal get solid by the time it reaches the floor?
I found that my release arm was not being pushed far enough forward by the slave cylinder because it was hitting inside the bellhousing. I guess this is because the adapter ring is desingned for the older crash box which has a boss on the clutch diaphragm. I had to pull the engine back out again, and make the release arm pivot about half inch longer to get the clutch to work and select all gears. Hope this helps.
Simon
Simon
1972 Rover 2000TC M16 turbo
1975 Land Rover OM606 diesel
