Engine resleeving
Engine resleeving
I have a ford 302 engine with some pretty serious scores down one of the bores. I've weighed up the pro's and cons for a rebore and have decided to have the cylinder resleeved so I can use standard sized pistons (it's only a standard rebuild)
Can anybody suggest a firm who can do this? I've tried Gosnays engineering in Romford, Essex. But they are so expensive I thought I'd shop around first.
Anywhere in the south east?
Any advice greatly appreciated.
Simon
Simon
Simon, see PM
the sleeves were direct from westwood trading (http://www.westwoodtrading.co.uk/news.asp)
the company were recomended by them as "a firm in your area that can do it" I will look out contact details when I get home, however westwood were very helpfull and cot me the name when I contacted them. I did not use them as my plans changed.
The cost was on the basis of boring and finnishing the rest of the block at the same time, but yes I thought it was pretty cheep, from what I remembered at the time Reel Steel weren't that much more expensive for a single sleeve on the same basis, just they charged retail for the sleves (about £30 each).
I get my machining done here, exelent work, normally at reasonable prices,
http://www.thurstonengineering.co.uk/co ... _frame.htm
THE SMOKING GNU
