Removed the engine today,
and we were a bit concerned when removing the passengers side manifold,
it looks as if cylinder 3 is running either lean, or no fuel, its shiney as if its just been ported,
never noticed a drop in power mate,
and it never lost any water,
will see what the pistons are like when the heads come off next weekend,
whats the easiest way to check the injectors to make sure they are correct,?
im also going to test the ecu loom from the plugs back to the ecu,
could this be one of the reasons it seemed low on the rollers in August?
and could this be assisting this missfire?
Obvious one to check is the cam, but its new , bent pushrod, I would guess blocked injector, especially if I remember correctly they are the first injectors in line,
Does you ECU batch fire, or fire individually??
THE SMOKING GNU
Ian, the car aint running yet, so it would of had the old crower cam and crane lifters,
we only took the engine out today from it coming off the road last yr,
